Caution: If you run a simulation by right-clicking and selecting Run Multithreaded Simulation, the results are not reproducible, even if you specify a random seed.
K-out-of-N blocks contain n identical components. The block fails when less than k of the components are functional. The following options are available for K-out-of-N blocks:
Specifies that stress is shared equally among the remaining functional components. This type of stress sharing is referred to as Load Sharing. The characteristic life of individual components is proportional to the number of components that share the work load.
Help created on 9/19/2017
