For example, using the Cities.jmp sample data table, specify a continuous Coloring variable as follows:
Select Graph > Treemap.
Click OK.
Note that the size of the rectangles is still based on the number of occurrences of the Categories variable, but the colors are mapped to ozone values. The high ozone value for Los Angeles clearly stands out. Missing values appear as black rectangles.
