For the C, Python, and JavaScript languages, you must include supporting code such as .h files and utility libraries when deploying or compiling the generated code. These files are available in your JMP installation folder inside the Scoring folder
The C scoring code that is generated must be compiled into a library and then linked into an application. You might use either a static or a dynamic link approach. The files jmp_lib.h, jmp_parms.h, and jmp_score.h needed for compiling and linking can be found in the Scoring/C folder in your JMP installation folder.
The file jmp_score.py that is needed to run your Python scoring application can be found in the Scoring/Python folder in your JMP installation folder.
The file jmp_score.js that is needed to run your JavaScript scoring application can be found in Scoring/JavaScript folder.
Tip: For models with an ifmax call, such as logistic or neural models for a categorical response, move temporary variable declarations before the method run() statement. Rename variable names to conform to SAS naming conventions.
