JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Graph Builder
• Add Multiple Variables to the X or Y Zone
You can assign more than one variable to the same drop zone. By visualizing multiple Y variables across multiple X variables, you can discover multivariate relationships and interactions.
To add a variable to the left or right of the existing X variable, drag and drop the variable into the X zone. Use the same method for adding a variable to the top or bottom of the existing Y variable.
When you click and drag a variable, a blue shape appears, symbolizing where the variable is added.
Related Information
Example of Adding Multiple Variables to the X or Y Zone
