Select Analyze > Fit Model.
Select the following columns and click Add: Country, Weight, Turning Cycle, Displacement, and Horsepower.
Click Run.
Save the prediction formulas to columns by selecting Save Probability Formula from the Nominal Logistic red triangle menu.
Select Analyze > Modeling > Partition.
Select the Country, Weight, Turning Cycle, Displacement, and Horsepower columns and click X, Factor.
Make sure that Decision Tree is selected in the Method list.
Click OK.
6.
Click Split 10 times.
7.
Save the prediction formulas to columns by selecting Save Columns > Save Prediction Formula from the Partition red triangle menu.
Select Analyze > Modeling > Model Comparison.
Click OK.
Select ROC Curve from the Model Comparison red triangle menu.
Select AUC Comparison from the Model Comparison red triangle menu.
