Select Graph > Contour Plot.
Select to Fill Areas.
6.
Click OK.
Note: By default, the contour plot uses Delaunay triangulation for generating the contour plot. From the Contour Plot red triangle menu, select Transform > Range Normalized to change the method for calculating the triangulations to a normalized scale ([0,1]) in both X and Y.
7.
From the Contour Plot red triangle menu, select Show Control Panel.
The Alpha slider appears.
8.
Click and move the Alpha slider to the right.
