This example uses Capacitor ALT.jmp and can be found in the Reliability folder of the sample data. It contains simulated data that gives censored observations for three levels of temperature, for a reliability study. Observations are shown as censored values at temperature levels of 85, 105, and 125 degrees Celsius.
Leave the Censor Code as 1.
7.
8.
9.
Select Weibull as the distribution.
10.
Keep Wald as the confidence interval method.
Fit Life by X Launch Window shows the completed launch window.
11.
Click OK.
Fit Life by X Report Window for Capacitor ALT.jmp Data shows the top half of the Fit Life by X report window.
Select Hours and click Y, Time to Event, Temp and click X, Censor and click Censor, and Weight and click Freq.
Select Custom as the Relationship from the list.
In the entry field for μ, enter 1, log(:Temp), log(:Temp)^2.
6.
In the entry field for σ, enter 1, log(:Temp).
7.
Select the check box for Use Exponential Link.
8.
Deselect the check box for Nested Model Tests.
9.
Select Weibull as the Distribution.
Custom Relationship Specification in Fit Life by X Launch Window shows the completed launch window using the Custom option.
10.
Click OK.
Weibull Estimates and Formulas for Custom Relationship shows the location and scale transformations, which are subsequently created and included at the bottom of the Estimates report section.
Analysis proceeds similarly to the Example of the Fit Life by X Platform, where the Arrhenius Celsius Relationship was specified.
