Open the Blenders.jmp sample data table in the Reliability folder.
Select Analyze > Reliability and Survival > Life Distribution.
Select Time Cycles and click Y, Time to Event.
Select Causes and click Failure Cause.
Select Censor and click Censor.
6.
Select Individual Best as the Distribution.
7.
Make sure that AICc is the Comparison Criterion.
8.
Initial Competing Cause Report
Estimated Failure Time for 10% of the Units
10.
Select Omit for bearing seal, belt, container throw, cord short, and engine fan (the causes with the fewest failures).
Updated Failure Time
Select Interval Type > Pointwise on the red triangle menu.
Nonparametric Estimates with a Fréchet Probability Scale
Select SEV in the Scale column.
Nonparametric Estimates with a SEV Probability Scale
1
