The following example uses the Fisher’s Iris data set (Mardia, Kent, and Bibby 1979). The Iris.jmp sample data table contains measurements of the sepal length and width and petal length and width in centimeters for three species of Iris flowers: setosa, versicolor, and virginica. To find characteristics that differentiate the three species, examine these measurements.
Open the Iris.jmp sample data table.
Select Graph > Parallel Plot.
Select Sepal length, Sepal width, Petal length, and Petal width and click Y, Response.
Select the Scale Uniformly check box.
Three Species in One Parallel Plot
From Three Species in One Parallel Plot, you observe the following:
From the Iris.jmp sample data table, select Graph > Parallel Plot.
Select Species and click X, Grouping.
Three Species in Different Parallel Plots
The following example uses the Big Class.jmp sample data table, which contains data on age, sex, height, and weight for 40 students. Examine the relationships between different variables.
Open the Big Class.jmp sample data table.
Select height and weight and click Y, Response.
Select age and click X, Grouping.
Select sex and click By.
6.
7.
Height and Weight by Sex, Grouped by Age
