Open the Iris.jmp sample data table.
Select Graph > Scatterplot 3D.
Select Sepal length, Sepal width, Petal length, and Petal width and click Y, Columns.
From the red triangle menu, select Normal Contour Ellipsoids. Notice that Ungrouped is already selected.
8.
Example of an Ungrouped Normal Contour Ellipsoid
6.
Select Grouped by Column.
7.
Select Species.
10.
Example of Grouped Normal Contour Ellipsoids
7.
Select Species and click OK. A different colored contour is displayed for each of the three species.
Changing the Nonparametric Density Contour Transparency and Density
Adding a Second Nonparametric Density Contour
