This example uses the Car Physical Data.jmp data table, which contains information about 116 different car models.
Click OK.
To rotate the report window, select Display Options > Horizontal Layout from the red triangle menu next to Weight.
Distribution of Weight
Using the results presented in Distribution of Weight, the planning specialist can answer the questions.
The default report window in Distribution of Weight provides a minimal set of graphs and statistics. Additional graphs and statistics are available on the red triangle menu.
Click OK.
Analyzing a categorical (ordinal or nominal) variable might include questions such as the following:
Click OK.
The report window includes a bar chart and a Frequencies report for country and type. The bar chart is a graphical representation of the frequency information provided in the Frequencies report. The Frequencies report contains the following:
