the Rows menu in the main menu
the Cols menu in the main menu
Right-click on the selected rows and select Hide and Exclude.
Use Hide/Unhide to hide observations in plots and graphs for most platforms. See Hide Rows and Columns.
For most platforms, data remain excluded until you select Exclude/Unexclude again.
Right-click on the selected rows and select Exclude/Unexclude.
Select Exclude/Unexclude from the Rows menu or Cols menu. You can also right-click rows or columns and select Exclude/Unexclude.
To exclude hidden observations from analyses, use the Exclude/Unexclude option. See Exclude Rows and Columns.
Observations remain hidden until you select Hide/Unhide again.
Right-click on the selected rows and select Hide/Unhide
Select Hide/Unhide from the Rows menu or Cols menu. You can also right-click rows or columns and select Hide/Unhide.
Data remain labeled until you select Label/Unlabel again.
Select Rows > Label/Unlabel from the menu.
Select Label/Unlabel from the Rows menu or Cols menu. You can also right-click columns or rows and select Label/Unlabel.
Right-click on the highlighted rows and select Rows > Colors.
Right-click on the selected rows and select Markers, and then select the marker shape.
Select Other to create custom markers. You can type alphabetic characters, numerals, and other keyboard symbols.
You can assign colors or markers to your data table rows based on the values found in a particular column. For example, in a column called Sex, you could assign all rows whose value is F a red circle marker. All rows whose value is M could have a green plus marker. These colors and markers replace the default black dot in plots and appear next to its row number in the data table.
Select Rows > Color or Mark by Column.
Click OK.
6.
See Delete Custom Color Themes for details about deleting custom color themes.
Select File > Preferences > Graphs.
Custom Color Theme Panel shows the color theme panels for both continuous and categorical themes (respectively).
Click New to create a new theme.
To distribute the colors evenly on the gradient, click Space Evenly.
To list the custom theme in the Sequential pane, select Sequential from the drop-list.
To list the custom theme in the Diverging pane, select Diverging from the drop-list.
To list the custom theme in the Chromatic pane, select Chromatic from the drop-list.
To discard your changes, click Cancel.
8.
Click Save to save the custom color theme.
9.
Click OK to close the color theme window.
You can select custom color themes as defaults from the Continuous Color Theme and Categorical Color Theme drop-down menus in the Graphs preferences. Only continuous color themes are available for continuous data. All color themes are available for categorical data.
In certain reports, such as treemaps and surface plots, you can select specific custom color themes. See the Basic Analysis book for details.
In Windows, the color themes that you create are defined in the JMP preferences file called JMP.PFS. If you use JMP on more than one computer (for example, at home and at work), you can copy the color theme definitions from one JMP preferences file to another. Custom colors are then available on both computers.
In a text editor (such as Microsoft Notepad) add this color theme to the preferences file on your other computer. The preferences file is located in your Users folder within the JMP or JMPPro folder.
On the computer that contains the customized JMP preferences, select File > New > Script.
Click the Run Script button .
Select View > Log (or display the open log).
Save the log as Log.jsl and open the file on the computer whose preferences you are updating.
7.
8.
Copy and paste the custom color definition from Log.jsl to JMP.PFS. The definition goes after Preferences( as shown in the following example:
Note: Be sure to include the closing parenthesis and comma. The code does not need to be indented. You can put the code in any valid location. Pasting it after Preferences( helps ensure that you do not delete any necessary parentheses or commas.
Click Delete.
6.
Click OK to save your changes and close the Color Themes window.
To clear all row states in the data table, select Rows > Clear Row States. To clear row states only in selected rows, select Rows > Clear Selected Row States.
All rows become included, visible, unlabeled, and show in plots as black dots. The Clear Row States command does not affect row states saved in row state columns.
You can lock a column in place so that when you scroll horizontally, the column remains visible. Highlight the columns and select Cols > Scroll Lock/Unlock. Note the following:
Columns remain scroll locked until you highlight the columns and select Scroll Lock/Unlock again.
