For the supported platforms in the Analyze menu, Automatic Recalc is turned off by default. However, for the supported platforms in the Quality and Process menu, Automatic Recalc is turned on by default, except for the Variability/Attribute Gauge Chart, Capability, and Control Chart.
For the supported platforms in the Graph menu, Automatic Recalc is turned on by default.
This example uses the Companies.jmp sample data table, which contains financial data for 32 companies from the pharmaceutical and computer industries.
Click OK.
6.
8.
Select Rows > Exclude/Unexclude. The point is excluded from the analysis and the scatterplot is automatically updated.
9.
Fit a regression line by selecting Fit Line from the red triangle menu. Regression Line and Analysis Results shows the regression line and analysis results added to the report window.
11.
Select Rows > Exclude/Unexclude. The regression line and analysis results are automatically updated, reflecting the exclusion of the point.
