Select Analyze > Distribution to open the Distribution launch window.
Click OK.
From the red triangle menu next to Distributions, select Stack to make your report horizontal.
6.
From the red triangle menu next to Profits ($M), deselect Outlier Box Plot to turn the option off.
7.
8.
Type 500 in the Specify Hypothesized Mean box.
9.
Click OK.
10.
From the red triangle menu next to Distributions, select Script > Save Script to Data Table.
Your data table now has a script named Distribution saved to it. From the red triangle menu for the script, select Edit to see the script.
11.
To run the script and reproduce your final report exactly, select Run Script from the red triangle menu for the script.
