The Categorical platform can produce results from a rich variety of organizations of data, as reflected in the tabbed panels that enable you to specify the analyses that you want. The Categorical platform has capabilities similar to other platforms. The choice of platform depends on your focus, the shape of your data, and the desired level of detail. The strength of the Categorical platform is that it can handle responses in a wide variety of formats without needing to reshape the data. Comparing JMP’s Categorical Analyses shows several of JMP’s analysis platforms and their strengths.
