The Actual by Conditional Predicted plot appears by default. It provides a visual assessment of model fit that accounts for variation due to random effects. It plots the observed values of Y against the conditional predicted values of Y. These are the predicted values obtained if you select Save Columns > Conditional Prediction Formula.
Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The conditional predictions are the predictions obtained from the model given by .
Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The conditional residuals are given as follows:
Shows the conditional residuals plotted against the conditional predicted values of Y. You typically want to see the conditional residual scattered randomly about zero.
Options that are appropriate for the model that you are fitting are enabled. See Marginal Profiler Plot for Treatment A for an example of a Profiler. See Surface Profiler Showing the Response Surface for MODULUS and Silica = 1.2 for an example of a Surface Profiler. For details about the profiler, see the Profilers book.
The initial Variogram report shows a plot of the empirical semivariance against distance. For additional background and details, see Spatial and Temporal Variability.
The nugget is the vertical jump from the value of 0 at the origin of the variogram to the value of the semivariance at a very small separation distance. A variogram model with a nugget has a discontinuity at the origin. The value of the theoretical curve for distances just above 0 is the nugget.
