JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Covering Arrays
Covering
Arrays
Detecting Component Interaction Failures
Covering arrays are used in testing deterministic systems where failures occur as a result of interactions among components or subsystems. The design goal is to reveal if any interaction induces a failure in the system. Application areas include software, circuit, and network design.
Since the tests are deterministic, the emphasis driving the design is the need to cover all required interactions. The Covering Arrays platform constructs highly efficient covering arrays. You can also exclude factor level combinations that are not feasible for your testing protocol.
Strength 3 Covering Array
Contents
Overview of Covering Arrays
Covering Arrays and Strength
Example of a Covering Array with No Factor Level Restrictions
Create the Design
Analyze the Experimental Data
Example of a Covering Array with Factor Level Restrictions
Create the Design
Covering Array Window
Factors
Restrict Factor Level Combinations
Design
Metrics
Output Options
The Covering Array Data Table
Covering Array Options
Technical Details
Algorithm for Optimize
Formulas for Metrics
