JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Graph Builder
• Create Map Shapes
Create Map Shapes
Use Graph Builder to create maps using the
Map Shape
zone. When a column contains the names of geographical regions (such as countries, states, provinces, counties), you can assign the column to the
Map Shape
zone. This creates a map of the regions.
See
Map Shape
in Create Maps
for details about creating map shapes.
