Select Tables > Subset.
The Subset Window
Click OK to create the subset table.
To subset by the levels of a column, select Subset by and select the columns that you want to categorize for the subset.
To keep the subset table linked to the original table, click the box beside Link to original data table. When you change values in one table, the other table is updated.
To include formulas from the original table in the output columns, click the box beside Copy formula. Include all columns needed for the calculation of the formula.
To keep this window open after clicking OK, check the box beside Keep dialog open.
Stratified Subsets
For stratified random samples with a specified sample size, two columns can be saved: Selection Probability and Sampling Weight. Check the corresponding check box to save these columns.
Once you have produced output that contains a histogram (by selecting Analyze > Distribution), you can use the histogram to create a new data table. The new data table contains the data in the histogram’s highlighted bars.
Subset Created from a Histogram
Once you have produced output that contains a Pareto Plot (by selecting Analyze > Quality and Process > Pareto Plot), you can use the Pareto Plot to create a new data table. The new data table contains the data in the Pareto Plot’s highlighted bars. To create a subset, double-click a highlighted bar.
