A mixture problem in three components can be represented in two dimensions because the third component is a linear function of the others. The ternary plot in Diagram of Ternary Plot Showing Piepel Example Constraints shows how close to one (1) a given component is by how close it is to the vertex of that variable in the triangle. The plot in Ternary Plot for Mixture Design illustrates a ternary plot.
Create the Piepel mixture data as shown previously, or open the table called Piepel.jmp, found in the Design Experiments folder of the Sample Data Library.
Choose Graph > Ternary Plot.
