To start a full factorial design, select DOE > Full Factorial Design, or click the Full Factorial Design button on the JMP Starter DOE page. Then, follow the steps below:
The steps for entering factors in a full factorial design are unique to this design. To add factors, see Entering Factors in a Full Factorial Design.
To enter factors, click either the Continuous button or the Categorical button and select the number of levels.
When you finish adding factors, click Continue.
Use the Output Options panel to specify how you want the output data table to appear, as illustrated in Output Options Panel:
Run Order gives options to designate the order you want the runs to appear in the data table when it is created. Choices are:
Values in the Pattern column describe the run each row represents.
