Select DOE > Screening Design.
Select Load Responses from the red triangle menu on the Screening Design title bar. Navigate to the Design Experiment folder in the Sample Data installed with JMP and open the file called Reactor Response.jmp.
Next, select Load Factors from red triangle menu on the Screening Design title bar. Navigate to the Design Experiment folder in the Sample Data installed with JMP and open the file called Reactor Factors.jmp.
Click Continue on the completed Screening design dialog. In the Choose Screening Type panel, click Continue again to see the list of designs in Design List for 5-factor Plackett-Burman Screening Design. Select the Plackett-Burman design, as shown.
Click Continue.
6.
Choose Sort Left to Right in the Output Options panel.
7.
Click Make Table to see the design runs shown in Listing of a 5-factor Placket-Burman Design Table.
Examine the data table and note the Pattern variable to see the arrangement of plus and minus signs that define the runs. This table is used in the analysis sections that follow.
