It has many fields in common with other profilers. The Benchmark field represents the value of the prediction formula based on current settings. Click Reset Benchmark to update the results.
The Optimization outline node enables you to specify the formula to be optimized and specifications about the optimization iterations. Click the Optimize button to optimize based on current settings.
