JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Profilers
Custom Profiler
• Custom Profiler Platform Options
Factor Settings
Is a submenu identical to the one covered on
Factor Settings
in Profiler
Log Iterations
Outputs iterations to a table.
Alter Linear Constraints
Allows you to add, change, or delete linear constraints. The constraints are incorporated into the operation of Custom Profiler. See
Linear Constraints
in Profiler
Save Linear Constraints
Allows you to save existing linear constraints to a Table Property/Script called Constraint. See
Linear Constraints
in Profiler
Simulator
Launches the Simulator. See the
Simulator section
