Creates n new formula columns, substituting references to column1 with columns from the list into the formula from the original column.
Uses the specified quoted marker theme: "standard", "hollow", "paired", "classic", or "alphanumeric".
For Color by Column, assigns colors in a chromatic sequential fashion based on the values in the highlighted column.
"Numeric", "Ordinal", "Rowstate", "Continuous", "Ordinal", and "Nominal" get only the specified types of columns. More than one can be specified. "String" returns a list of strings rather than a list of column references.
In PopAgeGroup.jmp, the Country and Year columns are labeled. The following script returns a list of the labeled column names.
Save the data table to the database named using the connection and table name specified. The Replace option replaces the existing database with the current database.
Sets the row ID display width to the expr in pixels.
Sets the format used for input and storage for the column. The argument is the name of any JMP format (for example, "ddmmyyyy" for a date column).
Sets the column display width to the n in pixels.
Sets the filter conditions for each column. The WHERE clause is used for all the columns listed. To use different WHERE clauses for different columns, send the Match message separately for each column.
