Creates a data table containing a row for each response with a column called Response Name that identifies the responses. Four additional columns contain the Lower Limit, Upper Limit, Response Goal, and Importance. Saving responses allows you to quickly load them into a DOE window.
Note: You can set a preference to always simulate responses. Select File > Preferences > Platforms > DOE. Check Simulate Responses.
