JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
• Destructive Degradation
Destructive
Degradation
Model Product Deterioration over Time
To measure a product characteristic, sometimes the product must be destroyed. For example, when measuring breaking strength, the product is stressed until it breaks. Because the test is destructive, there is only one observation per product unit. In such a situation, you can model product reliability using the Destructive Degradation platform.
The platform models how a (typically) nonnegative response changes over time. Observations are assumed to be independent and measure the value of the response and the time at failure. A large and flexible collection of pre-defined models is provided. The models include location-scale and log-location-scale distributions whose location parameters are functions of time. The models allow explanatory variables and additional parameters.
Note:
If you require a model that is not represented among the models provided, you can use the Degradation platform. See
in Degradation
For background on destructive degradation and reliability, see Escobar et al. (2003) and Meeker and Escobar (1998).
Destructive Degradation Example of Model for Adhesive Bond.jmp
Contents
Example of the Destructive Degradation Platform
Launch the Destructive Degradation Platform
The Destructive Degradation Plot Options and Models
Plot Options
Models
The Destructive Degradation Report
Model List
Model Outlines
Destructive Degradation Platform Options
Statistical Details for Destructive Degradation Models
