Use the options in the Window menu. Note that Arrange options are also available using the Arrange Menu in the bottom right corner of most windows.
To display the JMP Home Window, click the JMP Home Window button in the lower right corner of most windows, or hold down Control and press 1.
To show the data table for a report, click View Associated Data button in the bottom right corner of the report.
Tip: If you cannot see the Arrange Menu, JMP Home Window, and View Associated Data buttons, select View > Status Bars.
Thumbnail Previews of Open Reports
