Example Configuration - Weibull
For specified components, select Omit to disable the component (that is, the component fails).
From the Distribution list, select the appropriate property from the drop-list. See Distribution Properties for Components for details.
For Series and Parallel components, enter N (the total number of components contained in the component).
For K out of N components, enter K (the minimum number of components that must function) and N (the total number of components contained in the component).
For Knot components, enter the Minimum Available Dependences.
Provide Data Window
