Select File > Save As and save as the new name.
On Windows, select Window > Set Title.
A lock icon appears next to the data table name. To unlock the file, select Lock Data Table again.
If you make a data table read-only outside of JMP (for example, by changing its properties on Windows), the data table contains a note informing you that it is locked. See A Read-Only File. This type of lock allows users to edit the data table, but not save the changes.
Compressing a JMP (version 6 or higher) data table reduces the size of the stored file. You can still run analyses, assign characteristics, and so on. To compress a data table, click the red triangle menu next to the table name in the table panel and select Compress file when saved and save the data table.
After saving the data table, a compressed icon appears next to the data table name. To decompress the file, select Compress file when saved again.
In addition, you can configure JMP to always use GZ compression when saving by selecting Preferences > General > Save Data Table Columns GZ Compressed.
Note: The Compress file when saved option only decreases the file size. This command does not affect the memory required to analyze the data. To reduce both the file size and memory required for analyzing, use Cols > Compress Selected Columns. See Compress Selected Columns.
A table variable can contain textual information (for example, source information for the data), or a value that can be used by column formulas or JSL scripts. Table variable names appear in the table panel at the left of the data grid. See Table Variables in the Table Panel.
Table variables are used primarily to document tables. Many sample data tables installed with JMP contain a table variable named Notes. This variable provides details about the data (for example, the source of the data). The example in Table Variables in the Table Panel shows a data table that contains Notes as one of its table variables. JMP also automatically creates table variables when you create a design table using the Design of Experiments commands in JMP. The design table has a table variable named Design with the name of the design type as its value.
Table variables can also be incorporated in formulas that you build using the Formula Editor. These formulas calculate values for a column by referring to a table variable. For details about constructing a formula that uses table variables, see Reference Columns and Table Variables in Formula Editor.
You can also incorporate table variables into JSL scripts. See the Scripting Guide for details.
Select New Table Variable.
Click OK.
Select one or more table variables and press Delete, or right-click the selected variables and select Delete. You can also press Control, right-click the blank area inside the table panel, and then select Delete Selected.
To automatically complete various analyses and tasks, you can create a JSL script and save it to the data table. See Scripts Saved With the Data Table. For detailed explanations of scripts, see the Scripting Guide.
From the report window, click on the red triangle menu for the platform and select Script > Save Script to Data Table.
Open the Big Class.jmp sample data table.
Select Analyze > Fit Y by X.
Click OK.
6.
7.
From the red triangle menu, select Script > Save Script to Data Table.
Tip: If you want a particular script to run automatically every time the data table is opened, name the script OnOpen. Only one script saved in the data table can be set to run automatically. If you name the script Model (or model) in a Fit Model script, the launch window is automatically filled in based on the script when you select Analyze > Fit Model.
Select New Script.
If you are finished editing the script, click OK. The script appears in the Table panel and the window closes.
If you are not finished editing the script and want to save it, click Save. The script appears in the Table panel and the window remains open for further editing.
JMP can compare two open data tables and report the differences between data, scripts, table variables, column names, column properties, and column attributes. Character values that do not match exactly appear in the report. For numeric data, you can select a relative (or fuzzy) comparison. The numeric values are considered equal if they are within the relative error rate that you specify. The smaller the relative error, the more precise the comparison.
In one of the tables, select Tables > Compare Data Tables.
(Optional) Select Fuzzy Compare and enter the relative error to see numeric differences within the specified rate.
6.
Click Compare.
The Tables Info report shows the data table names and locations along with the numbers of columns and rows in each table. In Basic Information, you see that Big Class1.jmp contains one more row than Big Class2.jmp.
The first entry in Modified Data indicates that one row (N) has changed (or been replaced) in the first row of Big Class2.jmp. When you select the entry in the Difference Summary report on the left, the entry is highlighted in yellow, and the row flashes in the data table.
For a graphical view of the comparison, place your cursor over a colored cell in the Difference Plot. Modified Data shows that the name KATIE in Big Class1.jmp was changed to KIM in Big Class2.jmp. The entire first row is highlighted in the Difference Plot, which tells you that all values in that row are different.
In Deleted Rows, the second entry indicates that two rows were deleted beginning at row four. The deleted rows are highlighted in Big Class1.jmp on the left. And the Difference Plot specifies the different values. The name in row four of Big Class1.jmp was JACLYN and TIM in Big Class2.jmp.
In Identify New Rows, the third entry tells you that one row was added before what was originally row eight. The name in row eight of Big Class1.jmp was ROBERT. PETER is the name in row six of Big Class2.jmp.
Click the Previous difference and Next difference buttons above the Difference Summary to navigate from row to row.
Tip: Save the Difference Summary report to a data table by selecting Save Difference Summary from the red triangle menu.
Select Compare Table Properties from the red triangle menu to see differences in table scripts and variables. For example, Modified Table Script shows that the Distribution script in Big Class2.jmp refers to the height column rather than the weight column.
Select Compare Column Attributes and Properties from the red triangle menu to see differences in column notes, cell colors, and the like. For example, Modified Column Attributes and Properties shows that column notes and value colors differ in Big Class2.jmp.
