JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
• Enter and Edit Data
Enter and Edit Data
Perform Basic Data Table Tasks
After you import data into JMP or create a new data table, you can format your data to prepare it for analysis.
This chapter contains the following information:
Change formatting for numeric values
Add, delete, and select rows and columns
Use the Row Editor to navigate within rows and edit rows
Create scripts that are saved to the data table
The Rows and Cols Menus
Contents
Enter Data
Select Rows
Select Columns
Select Cells
Resizing Rows and Columns
Edit Data
Delete Rows and Columns
Edit or Delete Cells
Edit Column Names
View Patterns of Missing Data
Find and Replace Cell Values
Reorder Columns
Group Columns
Edit Data Tables
Change Table Names
Lock Tables
Compress Tables
Use Table Variables
Create and Save Scripts
Compare Data Tables
Assign Characteristics to Rows and Columns
Hide and Exclude Rows
Exclude Rows and Columns
Hide Rows and Columns
Label Rows and Columns
Assign Colors or Markers to Rows
Create Color Themes
Delete Row Characteristics
Lock Columns in Place
Restructure Data
