Use the Evaluate Design to analyze the diagnostics of an existing experimental design. Evaluate your designs to see the impact of a lost run or to assess the estimability of model effects. This information can help you understand the strengths or limitations of your experimental data. From the results, you can change the model terms and the aliasing terms. Then the diagnostics update accordingly.
D, G, and A efficiency
Contents
