This example uses the Dogs.jmp sample data table. This example shows you how to produce both a Matched Pairs Across Groups report and the corresponding MANOVA report using Fit Model.
Select Analyze > Matched Pairs.
Click OK.
The report on the left in Examples of Matched Pairs Across Groups and Fit Model MANOVA with Repeated Measures appears.
Select Analyze > Fit Model.
Select the Manova personality.
Click Run Model.
6.
7.
Click OK.
