This example uses the SAT.jmp sample data table. SAT test scores for students in the 50 U.S. states, plus the District of Columbia, are divided into two areas: verbal and math. You want to find out how the percentage of students taking the SAT tests is related to verbal test scores for 2004.
Select Help > Sample Data Library and open SAT.jmp.
Select Analyze > Fit Y by X.
Select 2004 Verbal and click Y, Response.
Select % Taking (2004) and click X, Factor.
Example of SAT Scores by Percent Taking
