Select Analyze > Multivariate Methods > Cluster.
Click OK.
The clustering sequence is easily visualized with the help of the dendrogram, shown in Hierarchical Clustering Report. Clustering occurs from left to right in the diagram, with each step consisting of the two closest clusters combining into a single cluster.
6.
From the Hierarchical Clustering red triangle menu, select Color Clusters.
7.
From the Hierarchical Clustering red triangle menu, select Constellation Plot.
