Select DOE > Definitive Screening Design.
Definitive Screening for Eight Continuous Factors
Click Continue and open the Color Map On Correlations report (Color Map for Definitive Screening).
6.
Select Save Factors from the Definitive Screening Design red triangle menu and name the file Design Factors.jmp.
7.
Select Save Responses from the same red triangle menu and name the file Design Responses.jmp.
Select DOE > Screening Design.
Select Load Responses from the Screening Design red triangle menu and then select Design Responses.jmp, which you created in the preceding steps.
The Fitness response appears in the Responses list.
Select Load Factors from the same red triangle menu and then select Design Factors.jmp.
Click Continue.
Select Choose from a list of fractional factorial designs and click Continue.
Fractional Factorial Screening Design
7.
Click Continue.
Color Maps for Fractional Factorial (left) and Definitive Screening (right)
