Fitting Commands and General Options
Attaches histograms to the x- and y-axes of the scatterplot. A check mark indicates that histogram borders are turned on. See Histogram Borders.
Example of the Fit Mean Fitting Command
Transforms Y and X. Transformations include: log, square root, square, reciprocal, and exponential. You can also turn off center polynomials, constrain the intercept and the slope, and fit polynomial models.
Fits a smoothing spline that varies in smoothness (or flexibility) according to the lambda (λ) value. The λ value is a tuning parameter in the spline formula.
Fits a value to each unique X value, which can be compared to other fitted lines, showing the concept of lack of fit.
Note: You can remove a fit using the Remove Fit command. For details, see Fitting Menu Options.
