Open a new script window (File > New > Script).
In your script window, enter the Open() expression to open the Solubil.xls sample import data file. The file is located in JMP’s Samples/Import Data folder.
Run your script to import the Excel file by selecting Edit > Run Script.
Note: You can specify an absolute or relative path to the file rather than using a path variable. For relative links, the script and file being opened must be in the same relative location each time you run the script. With absolute links, make sure that other users running the script have access to the file’s location. See Path Variables in Types of Data for more information about using pathnames.
With your new data table open, select Analyze > Distribution.
Click OK.
In the Distribution window, select Script > Copy Script from the red triangle menu next to Distributions.
6.
Place your cursor in the script window a line or two after your Open() expression and select Edit > Paste.
8.
Select Graph > Scatterplot 3D.
9.
10.
Click OK.
12.
Select Analyze > Multivariate Methods > Multivariate.
13.
14.
Click OK.
Specify a filename (for example, Weekly Report).
Click Save.
Select Edit > Run Script.
Select File > Open.
