The Scripting Guide book begins with basic information (such as terminology and syntax) for JMP users who are not familiar with the scripting language. The book progresses to more advanced information.
The Scripting Index on the Help menu provides a brief description and the syntax for JSL functions, objects, and display boxes. Each entry includes an example that you can run and modify to test your own code. And an embedded log window lets you see messages as examples are run.
Click the Search button to begin the search.
Click the Clear button to clear the search text box to begin a new search.
Click the Settings button to set search types and parameters.
Click an item’s Topic Help button to read more about the item in JMP’s online Help system.
Suppose you run the Distribution platform in the GUI and then select Script > Save Script to Script Window from the red triangle menu for the report. The following script appears:
