The Working with Your Data section shows you how to get data into JMP.
The Visualizing Your Data section shows you how to use some of the useful graphs JMP provides to look more closely at your data.
The Analyzing Your Data section shows you how to use some of the analysis platforms.
The JMP Starter
The Home Window on Windows
To open the Home window, select View > Home Window. On Macintosh, select Window > JMP Home. This window includes links to the following:
Macintosh sample data is usually at /Library/Application Support/JMP/<version>/Samples/Data.
From the Help menu, select Sample Data.
Open the Data Tables used in Discovering JMP list by clicking on the disclosure button next to it.
