You can also create models for profiling in JMP. See the Profilers book for details.
In your Excel worksheet, show the JMP add-in on the ribbon.
Click the Preferences button.
Accept the default Data Table Name (File name_Worksheet name) or type a name.
Select Use the first rows as column names if the first row in the worksheet contains column headers.
6.
Select Transfer Hidden Rows if the worksheet contains hidden rows to be included in the JMP data table.
7.
Select Transfer Hidden Columns if the worksheet contains hidden columns to be included in the JMP data table.
8.
Click OK to save your preferences.
Note: Empty cells are imported as missing data, and dates, numbers, and strings are recognized correctly.
Transfer the selected data in your Excel file to a JMP data table and launch the Fit Model platform.
