You import data from Internet sites, intranet sites, FTP sites, or other computers by selecting File > Internet Open. The file paths begin with the Uniform Resource Locators (URLs) http, ftp, or file; a drive letter; or the path to a network drive (relative or absolute).
You also use this feature to import a Web page on a local or network drive as a data table. Once the data table is created, there is a script called Source that you can run to re-import and refresh the data. If you open a web page by selecting File > Open, the page opens in a browser, not as a data table.
JMP inserts the location of the original data as a note in the data table. For example, the path Z:\example.html is included as a note when you import example.html from the Z drive.
Click the list under Open As, and select the option that specifies how you would like JMP to display the imported data:
Data Imports the file as a data table.
Web page Opens the web page in a browser. (Select this option to import data generated by web page scripts and server-side requests.)
Text Opens the file in a JMP Script window. In an HTML file, the HTML tags of a .html file are displayed.
Click OK.
If you imported a web page as data, a window appears that lists all tables on the page. Select the table or tables that you want to open, and then click OK. Each table opens in a new data table.
If you imported a web page as a web page, select File > Import Data as Data Table in the browser. Select the table or tables that you want to open, and then click OK. Each table opens in a new data table.
For an anonymous account, click OK. For an authenticated login, enter your user ID and password. The file then opens as you specified.
Note: Some anonymous FTP servers require a user ID. If the data table does not open, try typing either ‘ftp’ or ‘anonymous’ in the User ID text box. Leave the Password text box empty and click OK.
In the HTML view, select File > Import Table as Data Table.
Click OK.
See Run Stored Processes for more information about stored process reports.
