Static mode, where the bubbles are fixed and do not animate over time (no Time variable is specified). See Example of a Static Bubble Plot.
Dynamic mode, where the bubbles are animated over time (a Time variable is specified). See Example of a Dynamic Bubble Plot.
Animation Controls
<Time variable>
Separates the bubble represented by the first, larger ID variable into its smaller constituent parts, which are defined by the second, smaller ID column.
Reverses the action of the Split button by recombining the smaller bubbles back into their original bubble.
If the bubble is an aggregate based on an ID column, all of the rows for that ID are highlighted. Otherwise, the one row represented by that bubble is highlighted.
If you specify an ID and a Time variable, selecting a bubble highlights all of the rows for that ID, across all of the Time levels.
If you have not specified a Time variable, selecting one row from the data table highlights the corresponding bubble in the plot.
If you have specified a Time variable, selecting one row from the data table highlights the corresponding bubble for only that time period in the dynamic bubble plot.
Note: For a more granular examination of the highlighted rows, use the Tables > Subset command or the Row Editor. See the Using JMP book.
