Example of a Journal shows some of the items that you can add to a journal.
To create an empty journal, select File > New > Journal. Or, from the JMP Starter window, select New Journal.
To create a journal from most graphs, right-click on the graphic, and then select Edit > Journal. (Not available for surface plots and 3-D scatterplots.)
Write a JSL script to create a new journal. See the Scripting Guide for more information.
Select File > Save and save the journal in .jrn format.
To prevent modifications to a journal, right-click the blank area at the bottom of the journal and select Lock. Additional reports are not added to the journal (as described in the following section). JMP instead finds an open unlocked journal or creates a new journal when you select the Edit > Journal command again.
To append other reports to a report that you already journaled, select Edit > Journal again. If an area of an analysis window is selected, Edit > Journal saves only the selected area instead of the entire window.
Note: Links to files have absolute paths. If you move the journal to another location on your computer, the links continue to work. When adding links to files in the JMP sample data folder, use the pathname $SAMPLE_DATA/xx. xx is the absolute path from the sample data directory. (Right-click the link, select Edit > Set Script, and then edit the path.)
To add an outline level, right-click in the journal, and then select Append Item > Add Outline Item. You can also add nested outline levels to outline levels that you have created. (When you click the red triangle menu of a graph that you have journaled, the Add Outline Item option is unavailable.) Click the outline level’s red triangle menu and select Add Outline Item.
To edit a link, right-click the link, select Edit > Set Script, edit the path, and then click OK.
Creates outline levels and links to open files in JMP (except for the log). For example, a link to the open Big Class.jmp data table and chart is displayed below a collapsible heading named Big Class. Files such as journals, scripts, and tutorials are grouped below a collapsible heading called Other Files.
Copy a graph from within JMP or a graphic from another application and then select Edit > Paste. JMP places the graphic at the end of the journal.
To adjust text wrapping, right-click the text and select Set Wrap. Enter the number of desired pixels per line and click OK. To apply the wrap to all text items, select Set Wrap, select Extend this to other text boxes, and then click OK.
Select File > Save As.
Select File > Export.
Click Next.
Click Export.
Select File > Print.
Select File > New > Journal.
Add an Outline Item
6.
Select the Bullet Point check box and click OK.
Add Text Item
7.
Open the Big Class.jmp sample data table.
Add Window Reference
Change the Link to a Button
