JMP 12 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Specialized Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
• JMP Platforms
JMP Platforms
Launch and Report Windows
Most JMP platforms analyze and graph your data using launch windows and report windows. You specify your analysis in a launch window and your analysis and graphs appear in a report window. This chapter describes features that are common to all launch windows and reports.
Example of a JMP Launch Window and Report Window
Contents
Launch Windows
Platforms That Support Multithreading
Navigating Reports
Use the Hand Tool
Access Report Display Options
Show and Hide Parts of a Report
Combine Several Reports
Increase Font Sizes
How to Access Analysis Options
The Data Filter
Format Report Tables
Select Points in Plots
Use Markers
Alter Plot and Chart Appearances
Resize Plots and Graphs
Change Line Widths
Change the Background Color in a Graph
Change the Color of Histogram Bars
Display Coordinates and Temporary Reference Lines
Scroll and Scale Axes
Customize Axes and Axis Labels in the Axis Settings Window
Customize Axes and Axis Labels Using the Right-Click Menu
Change the Order of Values
Change the Pattern and Format of Selected Objects
Add Geographical Images and Boundaries
Drag and Drop an Image into a Graph
Extract Data from an Image
Add Graphics Elements to a Report
