Produces a separate report for each level of the By variable. If more than one By variable is assigned, a separate report is produced for each possible combination of the levels of the By variables.
After clicking OK, the Spec Limits window appears if you have not specified limits for the selected variables and Ignore columns with no spec limits is not selected. Otherwise, the report window appears.
