To launch the Nonlinear platform, select Analyze > Modeling > Nonlinear. The launch window is shown in Nonlinear Platform Launch Window.
Select the Y variable.
Select either the X variable or a column containing the model formula with parameters.
Tells JMP that if an ingredient column to the model is a column that itself has a formula, to substitute the inner formula, as long as it refers to other columns. To prevent an ingredient column from expanding, use the Other column property with a name of “Expand Formula” and a value of 0. This option is used only when a formula column is provided in the X, Predictor Formula role.
