The Mixture Profiler can incorporate linear constraints into its operations. To do this, a Constraint Table Script must be part of the data table. See Linear Constraints in Profiler for details about creating the Table Script.
When using constraints, unfeasible regions are shaded in the profiler. Shaded Regions Due to Linear Constraints shows an example of a mixture profiler with shaded regions due to four constraints. The unshaded portion is the resulting feasible region. The constraints are below:
4*p2 + p3 ≤ 0.8
p2 + 1.5*p3 ≤ 0.4
p1 + 2*p2 ≥ 0.8
p1 + 2*p2 ≤ 0.95
