The Actual by Predicted plot appears by default. It provides a visual assessment of model fit that reflects variation due to random effects. It plots the observed values of Y against the marginal predicted values of Y. These are the predicted values obtained if you select Save Columns > Prediction Formula.
Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The marginal predictions are the predictions from the fixed effects part of the predictive model, given by .
Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The marginal residuals are the residuals from the fixed effects part of the predictive model:
Shows the residuals plotted against the predicted values of Y. You typically want to see the residual values scattered randomly about zero.
Options that are appropriate for the model that you are fitting are enabled. See Marginal Profiler Plot for Treatment A for an example of a profiler. See Surface Profiler Showing the Response Surface for MODULUS and Silica = 1.2 for an example of a Surface Profiler.For more details, see the Profilers book.
