Both the Custom Design and Mixture Design platforms construct designs for situations where all of your factors are ingredients in a mixture. However, mixture experiments can involve non-mixture process variables, or process factors. The Custom Design platform can construct a design to accommodate both mixture ingredients and process factors. The Custom Design platform also allows the mixture components to sum to any positive number. See Advanced Options > Mixture Sum.
The response is Damping, which measures the electromagnetic damping of an acrylonitrile powder.
CuSO4 (copper sulphate), ranging from 0.2 to 0.8
Na2S2O3 (sodium thiosulphate), ranging from 0.2 to 0.8
Glyoxal (glyoxal), ranging from 0 to 0.6
The nonmixture environmental factor of interest is Wavelength (the wavelength of light) at three levels denoted L1, L2, and L3.
Wavelength is a continuous variable. However, the researchers were interested only in predictions at three specific wavelengths. For this reason, you treat Wavelength as a categorical factor with three levels.
Select DOE > Custom Design.
From the Custom Design red triangle menu, select Load Factors.
Click Interactions > 2nd.
An informational JMP Alert window reminds you that JMP removes the main effect terms for non-mixture factors that interact with all the mixture factors. This means that the main effect of Wavelength is removed, but all two-way interactions of mixture factors with Wavelength are added.
7.
Click OK to dismiss the message.
Note: Setting the Random Seed in step 9 and Number of Starts in step 10 reproduces the exact results shown in this example. In constructing a design on your own, these steps are not necessary.
9.
(Optional) From the Custom Design red triangle menu, select Set Random Seed, type 858576648, and click OK.
10.
(Optional) From the Custom Design red triangle menu, select Number of Starts, type 10, and click OK.
11.
Click Make Design.
Move the slider for Wavelength to verify that the relative prediction variance profiles for the mixture factors do not change across the levels of Wavelength. Move the slider for any one of the mixture factors. The factors for the other two mixture factors adjust to make the mixture ingredients sum to one. Notice that the smallest relative prediction variances occur near the center settings for the mixture factors.
From the Prediction Variance Profile red triangle menu, select Maximize Desirability.
Open the Fraction of Design Space Plot outline.
Over the entire design space, the relative prediction variance is below 0.8. The minimum relative prediction variance is about 0.32. As seen in Prediction Variance Profile for 18-Run Design, the minimum occurs near the center settings for the mixture factors.
Open the Design Diagnostics outline.
The design is optimal relative to the D-optimality criterion, even though its D-efficiency is very low (3.6%). Because mixture designs are far from orthogonal due to the mixture constraint, they typically have very low D-efficiencies. The Average (relative) Variance of Prediction is 0.410395. This is consistent with the Fraction of Design Space plot in Fraction of Design Space Plot for 18-Run Design.
Consider the ingredients that go into a cake. Dry ingredients include flour, sugar, and cocoa. Wet ingredients include milk, melted butter, and eggs. The wet and dry components of the cake are two mixtures that are first mixed separately and then blended together. Dry and Wet Components and Experimental Ranges lists the factors and the ranges over which you vary them as part of your experiment.
Note that the default goal is Maximize. Because you want to maximize the Taste rating, do not change the goal.
6.
7.
8.
In the Define Factor Constraints outline, select Specify Linear Constraints.
9.
In the Linear Constraints panel, click Add twice.
11.
In the Model outline, select any effect and click Remove Term.
12.
Type 10 next to User Specified.
Note: Setting the Random Seed in step 13 and Number of Starts in step 14 reproduces the exact results shown in this example. In constructing a design on your own, these steps are not necessary.
13.
(Optional) From the Custom Design red triangle menu, select Set Random Seed, type 1992991263, and click OK.
14.
(Optional) From the Custom Design red triangle menu, select Number of Starts, type 40, and click OK.
15.
Click Make Design.
16.
Click OK to dismiss the JMP Alert.
17.
Click Make Table.
The Cake Data.jmp sample data table shows the results of the experiment. The design table contains a Model script that opens a Fit Model window showing the five main effects specified in the DOE window’s Model outline. Notice that the main effect of Egg is not included in the Model outline for this design. This script was saved to the data table when it was created by Custom Design.
Open the Cake Data.jmp sample data table, located in the Design Experiment folder.
In the Tables panel of the design table, click the red triangle next to Model and select Run Script.
The main effect due to Egg is not included because it was excluded from the Model outline in the Custom Design window. All five effects are designated as Response Surface and Mixture effects.
Click Run.
The Parameter Estimates report indicates that Sugar, Flour, and Butter are significant at the 0.05 level.
